Müsste eine abgespeckte Mazatrol Steuerung sein:
DESCRIPTION
CNC vеrtical machining center
MAZAK type impulse 30 H
CNC 3D contouring MAZATROL IMAC TP V5. 0
Routes x 430 mm, Y: 300 mm Z: 250 mm
Table size 600 x 400 mm
ISO 30 spindle adaptor
Distance spindle nose – table 175-425 mm
Distance from spindle axis to the tool magazine 105-405 mm
Table load of 150 kg
Tool weight of 2 kg
Spindle speed continuously variable 30-10,000 rpm.
Feed X, Y, Z – axis 0 to 12 m / min.
Rapid traverse speed X, Y, Z – axis 24 m / min.
Spindle drive 6 kW
Power supply 400 Volt, 50 Hz
-CNC 3D contouring MAZATROL IMAC TP V5. 0
-Indirect measuring system with rotary encoders on the ball screws
-Tool changer with 10 tool stations (2 x 5 places)
-Internal Coolant inner coolant supply for pressure spindle flush
-Chip tray with coolant system at right behind the machine
-Full cab with sliding door
-Lighting of workroom
-7 piece tool holders
-Power transformer box opposite
-Read off duty hours “Control a” = 1723 hours
Dimensions L x W x H 2000 x 1350 x 2350 mm
link:
http://servotek-gmbh.com/en/shop/mazak-133/
Der Beitrag wurde von brueckmeister bearbeitet: 14.02.2019, 16:58 Uhr
