585.978 aktive Mitglieder*
4.438 Besucher online*
Anmelden Registrieren
INDEX-Gruppe Forum
better.parts.faster.
TND 200 1991/1992, Parameters
Beitrag 27.01.2021, 13:37 Uhr
MACS
MACS
Member
Dear All
I have two machine TRAUB TND 200 with TX8F:
I have a huge problem to find any one who have the some machine the nearest I found TND 160 but it seems the parameters are a little different.
If some one can help.
I think the biggest problem is with M_PARAM 12 [BIT-SELECT]
The machine have driving tools, chip conveyer and hydraulic tail stock, Revolver BARUFFALDI.
I have comunnication with the machine by RS without problem on both side.
I only heard about adoption procedure but no one was ready to visit and fix the machine.
Rigt now Machine START-UP, Hydraulic START UP, I can move X, Z axies and run chip conveyer that's all.
No possible to move revolver, tailstock, cooling pump, ...
Please help me of if it is possible share the photo directly from Your machine
Angehängte Datei(en)
Beitrag 28.01.2021, 16:55 Uhr
KBess
KBess
Hello,
i have had the same pronlem 1 year ago. If you have the machine number give Index a call. They will send you the Parameter list.
My machine have no chip conveyer
M_Parameter 12 BIT SELECT TND200 o. Sore + Späfö
Maschine mit C-Achse, rot. Werkzeug, mit Reitstock
#1 00101111
#2 01011111
#3 01111100
#4 00000011
#5 00000100
#6 10010000
#7 00000010
#8 01000000
#9 10000000
#10 00001000
#11 00000000
#12 00000000
#13 00000100
: 00000000
#17 00000001
#18 10000000
: 00000000
#20 00010100
: 00000000
#24 00010000
#25 00001000
: 00000000
#27 00010000
: 00000000
#33 10000001
: 00000000
#50 00000111
: 00000000
#57 00001001
: 00000000
#61 00000001
: 00000000
Regards
Beitrag 28.01.2021, 18:47 Uhr
MACS
MACS
Member
Many Thanks a lot.
I have orginal document from MELDAS but when I put in by hand the machine even don't turn hydrulics.
I attached file with Parameters which I recived from TRAUB-INDEX accoding to Machine No. PARA3 but this wich I try is from 160 PARA2.
Today I got RED surprise.
Best Regards
Beitrag 28.01.2021, 19:33 Uhr
KBess
KBess
not shure - your battery of the cnc is down? Let the machine switched on for a couple of hours.
With the 2 files - i can not read parameters (or programs) into the machine. Index send me a list which i type direct in the machine.
Regards
Der Beitrag wurde von KBess bearbeitet: 28.01.2021, 19:39 Uhr
Beitrag 29.01.2021, 00:42 Uhr
MACS
MACS
Member
Thanks a lot again. I change first only two batteries which I saw now I read that there is also next in the cards.
I will change them tomorrow.
I aso recived the Parameters from Index-Traub directly but it seems I am not lucky person.
It is possible to share this by e-mail I wrote on Prviate message. I will try maybe Your configuration will start working ?
Regards
Beitrag 01.02.2021, 23:54 Uhr
MACS
MACS
Member
Dear Sirs
At first I would like to MANY THANKS for help from Index-TRAUB Service. I recived file with some proper parameters I think.
The machine start talk only 4 problems still don't close the subject:
1. Confirmation of hydraulic chuck close / open. I suspect indicator or timer settings/delay between hydraulics and Indicator ?
2. Tailstock not moving
3. BARUFFALDI settings or how to SET-UP properly in the PLC-SW #38 00001100 right now ?
4. Parameters for driven tools ?
If any one have the some machine please help.
Regards
Beitrag 22.02.2021, 22:49 Uhr
MACS
MACS
Member
Hello All
Today next huge progress thanks Service TRAUB from GERMANY.
I at least :
1. Rotate the spindle even together with live tool spindle ?
2. Still have problem with BARUFFALDI sometime change 1 or 2 position forward or backword then stock.
Any one can share Parameters for live tools in TND 160/200/300/400 or any other from 90-96 ???
