ich versuche grade den alten 486er durch einen moderneren PC zu ersetzen und habe mir ein paar
DNC Programme runtergeladen.
Alle funktionieren von der eigentlichen Kommunikation her sofort aber das was ankommt ist nicht so schön, denn das sieht so aus:
f~~fx~~~~~f`x~~~`~~`~f`x~~fx`~~f~x~xf`x~~fxx~`x~~x~x~f`x~~fxfx~xx~~fxx~`~f`x~~~x~`~~`~fxxxx~~~x~`x~`~xx~fx`~x`~~f`x~~~~`x~~~~~`~x~~fx~`x~~~xxfx~f`x~~fx~`~~xx~`x~x~~fx~~`~~~~f`x~~fxxx~`x~`~x~~~fx~`x~~~x~f`x~~~~`~~xx~`x~x~~~xx~`~~~~xxxx~~`~x~`~~ff`~xfxx~~`~`~~`x~~~fx~x~x~~~x~`x~x~x~~xx~`~~~fx~~`x~fxx~~~~~`x~`~x~~`~~`x~~~fxf`x~~`~~`~~xx~x~~`~~~`~~~x`~x~~`~xx~`~~x`~`~~x~~xx~`~~~~xx~~x~~`x~`~x~~x~~`x~~xx~f`x~~xx~`~~xx~x~~x`~~`x~~~x~xxx~~xfx~`x~`~x~~`~x~`~f`x~~`~~`x~xxxx~fxx~xf`x~~`~fx~`x~~x~x~f`x~~xxx~`~~xxxx~`xxfxx~~x~~~`x~x~xxx~~x~~`~`~x~~xx~`x~`~xxx~f~x`~x~xf`x~~xx~`x~~x~x~f`x~~~~~`~~~x~x~f`~~~~`~~`~x~f~~`xxf`x~~~xx~`~~xx~`~~xxx~~x~~`x~xx~`~~xxx~xf`x~~x~~`x~~x~`~x~~~~``~xf`x~~x~`~~~~fx~xfx~`x~~f`x~~xx~`~~x~`xxf`x~~x`~~~`~~~xx~~fx~xx~x~~xfx~`~~xxxx~~xxx~`~~~~~xx~~x~~~`~~~~x~fxxxx~~x~~`~~x`~`~xx~~xx~~`~~~xfxx~xxfx~xxxf`x~~x~`~~xx~~xx~xxxf`x~~~~`~~~~xx~~fx~xx~xxxf`x~~~~`~~xxx~~xxx~~fxx~``~xx~~x~`~~~~fxx~~`~~`x~xf`x~~fx~`~f`x~~xxx~`x~~x~fxxx~xf`x~~~~`x~~~x~xf`x~~~~`x~~~~xxx~~f`x~~x~`~~~x~`xxf`x~~`~~`x~~~f`x~~fx~`x~x~xxx~~xx~`~f`x~~~~~xx
Diverse Baudraten, Parity, Xon/Xoff hab ich geändert, hat aber nichts verändert.
Da es bei drei verschiedenen Programmen die gleiche Ausgabe liegt denke ich es liegt an der Maschine.
Jemand eine Idee was da falsch sein könnte?
Es ist eine CTX 400 Bj.88
Danke im Vorraus
Jan
