habe das mal selber geschrieben,musst du in Visual Quick Code einfügen.
Ist für Metrische und Zollgewinde(Innengewinde passt,Aussengewinde habee ich noch nicht getestet).Muss du halt anpassen.
Gruß Jürgen
N900
(CATEGORY)
(NAME GEWINDEFRAESEN)
N901
(TEMPLATE)
(NAME I.D. Gewindefraesen METRISCH)
(DIAGRAM)
(LINE [40,0] [40,1]) (CENTER LINES)
(LINE [0,0] [0,1])
(DATUM [19,14])
(CIRCLE [19,14] 13)
(LINE [23,15] [25,13])
(LINE [25,15] [23,13])
(LINE [29,15] [31,13])
(LINE [31,15] [29,13])
(ARROW [20,14] [23,14])
(CCW [30,16] [24,16] 4)
(LINE [24,17] [24,16])
(LINE [24,16] [25,16])
(CCW [24,12] [30,12] 4)
(LINE [30,11] [30,12])
(LINE [29,12] [30,12])
(LINE [5,31] [5,24])
(LINE [33,31] [33,24])
(ARROW [15,30] [5,30])
(ARROW [23,30] [33,30])
(PRINT [13,20] XPos,YPos=Mitte)
(END DIAGRAM)
(PARAMETERS)
(#DPos)
(NO DECIMAL)
(#ThrdDpth)
(LABEL GwndSchntief)
(#AnzGwSt)
(LABEL AnzahlGwSteigung)
(NO DECIMAL)
(#Feedrate)
(LABEL Vorschub)
(#MajorDia)
(LABEL GewindinnenD)
(POSITION [16,32])
(#ThdPitch)
(LABEL Steigung)
(END PARAMETERS)
(GCODE)
N1 (#660=1)
N1 (#661=#AnzGwSt)
N1 (G00 Z#ThrdDpth )
N1 (G91)
N1 (G01 G42 Y[#MajorDia/2] D#DPos F#Feedrate)
N1 (WH[#661GE#660]DO1)
N1 (G02 J-[#MajorDia/2] I0 Z[-#ThdPitch])
N1 (#660=#660+1)
N1 (END1)
N1 (G00 G40 Y[-#MajorDia/2] )
N1 (G90)
N1 (G00 Z5.)
N1 (M99)
(END GCODE)
(END TEMPLATE)
N902
(TEMPLATE)
(NAME A.D. Gewindefraesen METRISCH)
(DIAGRAM)
(LINE [0,0] [0,1])
(DATUM [19,14])
(CIRCLE [19,14] 13)
(LINE [33,15] [35,13])
(LINE [35,15] [33,13])
(LINE [39,15] [41,13])
(LINE [41,15] [39,13])
(ARROW [38,14] [36,14])
(CCW [40,16] [34,16] 4)
(LINE [34,17] [34,16])
(LINE [34,16] [35,16])
(CCW [34,12] [40,12] 4)
(LINE [40,11] [40,12])
(LINE [39,12][40,12])
(END DIAGRAM)
(PARAMETERS)
(#XPos)
(#YPos)
(#DPos)
(#ThrdDpth)
(#Feedrate)
(LABEL Vorschub)
(#AnzGwSt)
(NO DECIMAL)
(#MinorDia)
(LABEL GewindaussenD)
(POSITION [16,31])
(#ThdPitch)
(LABEL Steigng)
(#CuterRad)
(LABEL Fraesrradius)
(END PARAMETERS)
(GCODE)
N1 (#660=1)
N1 (#661=#AnzGwSt)
N1 (G01 Z[-#ThdPitch+#ThrdDpth] F1254.)
N1 (G41 Y[#YPos+#ArcInOut] D#DPos)
N1 (G02 I-[#MinorDia/2] J0 Z-#ThrdDpth )
N1 (G03 I-[#MinorDia/2] J0 Z[-[#660*#ThdPitch]+#ThrdDpth])
N1 (#660=#660+1)
N1 (END1)
N1 (G01 G40 X[#XPos+#MinorDia/2+#ArcInOut] Y#YPos)
N1 (G00 Z5.)
N1 (M99)
(END GCODE)
(END TEMPLATE)
N903
(TEMPLATE)
(NAME I.D. Gewindefraesen ZOLL)
(DIAGRAM)
(LINE [0,0] [0,1])
(DATUM [19,14])
(CIRCLE [19,14] 13)
(PRINT [0,5] R1/8"=0.125)
(PRINT [0,7] R1/4"=0.25)
(PRINT [0,9] R3/8"=0.375)
(PRINT [0,11] R1/2"=0.5)
(PRINT [0,13] R3/4"=0.75)
(PRINT [30,5] R1"=1.0)
(PRINT [30,7] R1 1/4"=1.25)
(PRINT [30,9] R1 1/2"=1.5)
(PRINT [30,11] R2"=2.)
(END DIAGRAM)
(PARAMETERS)
(#DPos)
(NO DECIMAL)
(#ThrdDpth)
(#Feedrate)
(LABEL Vorschub)
(#AnzGwSt)
(NO DECIMAL)
(#GwBez)
(LABEL Gewindebez.)
(END PARAMETERS)
(GCODE)
N1 (#660=1)
N1 (#661=#AnzGwSt)
N1 (#662=#GwBez)
N2 (#667=0.907)
N1 (#675=9.7)
N1 (IF[#662 EQ 0.125]THEN #667=0.907)
N1 (IF[#662 EQ 0.250]THEN #667=1.337)
N1 (IF[#662 EQ 0.375]THEN #667=1.337)
N1 (IF[#662 EQ 0.500]THEN #667=1.814)
N1 (IF[#662 EQ 0.750]THEN #667=1.814)
N1 (IF[#662 EQ 1.000]THEN #667=2.309)
N1 (IF[#662 EQ 1.250]THEN #667=2.309)
N1 (IF[#662 EQ 1.500]THEN #667=2.309)
N1 (IF[#662 EQ 2.000]THEN #667=2.309)
N1 (IF[#662 EQ 0.125]THEN #675=9.7)
N1 (IF[#662 EQ 0.250]THEN #675=13.14)
N1 (IF[#662 EQ 0.375]THEN #675=16.68)
N1 (IF[#662 EQ 0.500]THEN #675=21.0)
N1 (IF[#662 EQ 0.750]THEN #675=26.45)
N1 (IF[#662 EQ 1.000]THEN #675=33.26)
N1 (IF[#662 EQ 1.250]THEN #675=41.9)
N1 (IF[#662 EQ 1.500]THEN #675=47.8)
N1 (IF[#662 EQ 2.000]THEN #675=59.6)
N1 (G91)
N1 (G01 G42 Y[#675/2] D#DPos F#Feedrate)
N1 (G02 J-[#675/2] I0 Z[-#667])
N1 (#660=#660+1)
N1 (END1)
N1 (G00 G40 Y[-#675/2])
N1 (G90)
N1 (G00Z5.)
N1 (M99)
(END GCODE)
(END TEMPLATE)
N904
(TEMPLATE)
(NAME A.D. Gewindefraesen ZOLL)
(DIAGRAM)
(LINE [0,0] [0,1])
(DATUM [19,14])
(CIRCLE [19,14] 13)
(END DIAGRAM)
(PARAMETERS)
(#XPos)
(#YPos)
(#DPos)
(#ThrdDpth)
(#Feedrate)
(LABEL Vorschub)
(#AnzGwSt)
(NO DECIMAL)
(#MinorDia)
(LABEL GewindKleinD)
(POSITION [16,31])
(#ThdPitch)
(LABEL Steigung)
(#CuterRad)
(END PARAMETERS)
(GCODE)
N1 (#660=1)
N1 (#661=#AnzGwSt)
N1 (#662=0.907)
N1 (#663=1.337)
N1 (#664=1.814)
N1 (#665=2.309)
N1 (#660=#660+1)
N1 (END1)
N1 (G00 Z5.)
N1 (M99)
(END GCODE)
(END TEMPLATE)
(END CATEGORY)
