11917
Follower:innenIch habe die Parameter verloren DMU 70V 1998 MILLPLUS V330
27.06.2014, 12:23 Uhr
Hello
Sorry for my English but i'm French.
I have a DMG DMU 70V from 1998 using MILLPLUS V330 (Philips control) and i had a problem with the RAM memory. The technician said to me to put off the EPC-8 card and to leave the lithium battery to empty the memory.
But he didn't said that, I will loose the BIOS parameters.
Now i have problems to find all the informations and because i start my business, i have not enough money to paid a DMG technician to repair it.
I hope i can find here somebody who have the same machine and can give me photos of his BIOS parameters to copy that in my machine.
Please help me, I'm very in trouble!!!
27.06.2014, 12:47 Uhr
mtronik-kit
Hello
Hi there,
send me a picture of the controller in the control cabinet
best regards
mtronik
27.06.2014, 13:52 Uhr
Hi there,
best regards
mtronik
best regards
mtronik
27.06.2014, 13:53 Uhr
27.06.2014, 14:20 Uhr
mtronik-kit
Hi there,
I need the data from the hard disk
Please expand the EXM-HD and make a picture from the back.
best regards
best regards
27.06.2014, 15:21 Uhr
Hi there,
best regards
best regards
It is this you want????
27.06.2014, 15:53 Uhr
mtronik-kit
that's OK
I will create the parameters.
Please wait a moment ....
27.06.2014, 16:16 Uhr
mtronik-kit
that's OK
here are the specs .....
if you have to ask, please contact
best regards
Angehängte Datei(en)
27.06.2014, 16:20 Uhr
27.06.2014, 16:28 Uhr
mtronik-kit
I have another page in the BIOS
his name is VME with 3 options : PRIORITY - ARBITRATION - ULA
Do you know how to configure this page??
PRIORITY : 0
ARBITRATION: ROUND ROBIN
Bus Release: RONR (VXI)
ULA: 00
Beste regards
mtronik
27.06.2014, 16:29 Uhr
The machine do that at starting and it reboot again and again.
i give a youtbe video from my startup machine.
27.06.2014, 16:50 Uhr
mtronik-kit
are the machine parameters OK?
if not:
at boot Heidenhain-service menu
enter Y
Load default parameters
27.06.2014, 17:00 Uhr
if not:
enter Y
if not:
enter Y
I have enter your BIOS parameters and there is no more alarm BIOS.
But for the heidenhain service menu, i can only put S"button" to enter the menu and i have only this choice.
27.06.2014, 17:17 Uhr
mtronik-kit
Hello,
The problem is the following,
the machine parameters are incorrect or not in the area
therefore, the cpu does not load the NC software
in your software, the machine parameters can not be returned Act.
The CPU must be returned to a test stand, and the machine parameters are loaded.
Do you have original diskettes from the machine?
27.06.2014, 17:25 Uhr
Hello,
Yes i have all the diskettes from the machine. so what is the solution?? i can't resolve it myself?? I have the cnc install software where there a restore system option.
Is it difficult to do it myself??
27.06.2014, 17:34 Uhr
mtronik-kit
It is well, installed the software.
there is a program "CNC-INST"
can then start the program?
27.06.2014, 17:49 Uhr
The software is installed on my PC who run Under Windows 98.
I start cnc install -- ok
I select the option restore system -- ok
it ask me if it is analog/analog+digital/digital axis and if it is flash rom/hard drive (i don't know for the axis!!)
there a choice named "detect" -- i do detect
it open a msdos window with "wait4com.exe" host mode waiting for connection
i reboot the cnc
and the cnc arrived on "wait4com" but doesn't detect the communication with the PC.
27.06.2014, 18:00 Uhr
mtronik-kit
the problem is that the computer needs a DOS operating system
the programs address the hardware directly
this is not possible in win98
do you have a DOS computer
27.06.2014, 18:06 Uhr
27.06.2014, 18:14 Uhr
mtronik-kit
Even i restart in msdos MODE???
I have msdos 6.22 on diskettes but in my house.
that will not do .. you need a dos-computer
27.06.2014, 18:17 Uhr
27.06.2014, 18:42 Uhr
mtronik-kit
ok
and if I install msdos 6.22 on a empty hard drive with no other things and i put only this hard drive in the PC does it will work??
yes, that should work
15.11.2014, 11:49 Uhr
Dear Sirs,
we are a small company and we need help, we recently bought a machining center Maho MH 1200 S, the year of manufacture 1996, which owns HEIDENHAIN milplus steering that does not work, when examination revealed the panel with power PE1927 / 71 does not work, but we managed to fix it so that we have get all the required output voltages. When switching on the machine on the control unit display we still have nothing. LED-s od cards, such as the EPC 8 and all other have shine red, and hard drive we've tested on the computer and realized that it does not work. What so we do? Thank you in advance.
15.03.2016, 10:56 Uhr
I have a DMG DMU 70V from 1998 using MILLPLUS V330 (Philips control).There is such a problem.The machine is always rebooting.there is a fault such "no sysclk detected" and it always reboot.what can be the cause? I tried to change the bios Battery. Nothing changed.
15.03.2016, 14:22 Uhr
mtronik-kit
Hello,
is the fan in the rack OK?
I suspect that the rack is defective.
greeting mtronik
