ich hätte da eine Lösung für Sie:
Kühlschmierstoff, metal working fluid ? lösungsmittelfrei ? solvent-free ? ölfrei ? oil-free ? biologisch schnell abbaubar ? biological fast degradable ? wasserlöslich ? water-soluble ? dermatologisch geprüft ? dermatological approved Derma Protect und Innovation GmbH , Siemensstrasse 6 , D-88048 Friedrichshafen Telefon +49 7541 591 224 , Telefax +49 7541 591 225 SKV-02
Lösungsmittelfreies, ölfreies Metallbearbeitungskonzentrat, zur Verwendung in geschlossenen Maschinen- und Anlagenkreisläufen.
Solvent-free, oil free cutting and metalworking fluid for closed cooling-systems
SKV-02
belongs to a brand new generation of fullysolvent-free professional (oil-free) metalworkingfluids, developed by DPI metalworking divisionwith long experience and with the uniqueBPALWO-technique. (Better Performance andLubrication without Oil).
Is based on lubricating components, partly usedin the food-industry. It does not contain anytype of vegetable-, white-, mineral oil, solventsor chlorine. The product does not allow to bemixed with any kind of oil, or oil emulsion.Therefore, there is no risk for the product to becontaminated by any kind of oil, such as leak-oils, etc.
Is a multi purpose product and will performperfectly well by almost all types of
metalwork,such as cutting, drilling, grinding, tapping, etc. Itcan be used for all types of metal andtherefore, there is no need to stock a widerange of various other types of products.
Is built on readily biodegradable components. Itis harmless to handle and gentle to work with.The surrounding of the workplace will stay moresafety and comfortable.
Has extremely good cooling and cuttingproperties and provides a protective-filmagainst corrosion on work-pieces andmachinery. The surface will not be sticky, andthe machinery will stay clean.
SKV-02
ist eine völlig neu entwickelter, lösungsmittelfreier,professioneller Kühlschmierstoff, den DPI mit Ihrer lang-jährigen Erfahrung auf dem Sektor des Hautschutzes,nach der neuen Produkt- und Entwicklungsstrategie(BPALWO)entwickelt und herstellt. Better Performanceand Lubrication without Oil , bessere Eigenschaftenals Kühlschmierstoffe die unter Verwendung von Ölarbeiten.
Basiert auf Grundstoffen, die normalerweise in derLebensmittelindustrie verwendet werden, diese sindvöllig frei von Ölen und Lösungsmitteln. Das Produktvermischt sich nicht mit Leckölen, mineralischen-,natürlichen- sowie anderen Weissölen.
Ist ein Mehrzweckprodukt und kann bei fast allenMetallen eingesetzt werden. Dazu gehört gehärteterStahl, Eisen, Titan, Kupfer, Messing, Aluminium undviele andere Werkstoffe. Es wird eingesetzt beimbohren,
drehen,
schleifen, trennen,
fräsen und vielenanderen Anwendungen der Metallbearbeitung. Eserspart den Einsatz und Bevorratung von mehrerenKühlschmierstoffen, die für spezielle Anwendungenpräpariert sind.
Ist aus Komponenten hergestellt die biologisch schnellabbaubar sind. Das Produkt ist hautverträglich,dermatologisch geprüft für Ihre Mitarbeiter absolut un-bedenklich. Ihre Maschinen werden durch einen ein-gearbeiteten Korrosionsschutz geschützt. Ihre Ein-richtungen sind nach der Anwendung in einemsauberen Zustand, als bei Verwendung von ölhaltigenKühlschmierstoffen, außerdem haben Sie einenBeitrag zum Schutze unserer Umwelt geleistet.
Besitzt sehr gute Kühleigenschaften und fördert dieSchnittgeschwindigkeit, das Werkstück und dieMaschineneinrichtung wird mit von einem vorKorrosion schützenden Film überzogen.
Die Oberflächen des Werkstückes werden nichtklebrig und die Maschinen/Vorrichtungen werdensauber gehalten. Eine erhebliche Kostenersparnis inSachen Maschinenreinigung.
Mail :
[email protected] , Internet : www.dpi-metalworking.de Seite 1 von/from 2 Kühlschmierstoff, metal working fluid ? lösungsmittelfrei ? solvent-free ? ölfrei ? oil-free ? biologisch schnell abbaubar ? biological fast degradable ? wasserlöslich ? water-soluble ? dermatologisch geprüft ? dermatological approved Derma Protect und Innovation GmbH , Siemensstrasse 6 , D-88048 Friedrichshafen Telefon +49 7541 591 224 , Telefax +49 7541 591 225
SKV-02
Needs a concentration of 3% (Ref. factor 1,2)for grinding and 6% (Ref. factor 2,4) for all otherapplications.
A must for a optimal result is a previous propercleaning of tanks and machineries andsurroundings, before filling the product. Theunique long life of the product can only beassured when cleaning and disinfection is doneby DPI SC 66. DPI SC 66 has to circulate insidethe cooling-system (concentration of 2% - mixedwith medium warm water)for at least 30minutes. Make sure that the system is filled up tomaximum . If needed add water. Rinse until thedisinfectant is totally gone.
Detailed information about health, protectionand environment you will find in the material-safety-datasheet. It contains information aboutrisks, first aid, environmental-effects and alsoabout disposal of used product.
Package : Can 5 and 30 lit, Drum 210 lit and Container 1000 l
SKV-02
Die empfohlene Konzentratbeigabe liegt für einfacheAnwendungen (Schleifen) bei 3% (Refraktometer 1.2)und 6% (Refraktometer 2.4) Beigabe bei den übrigenAnwendungen.
Ein Muss für ein optimales Anwendungsergebnisunddie einmalige lange Lebensdauer des Produktes, beimEinsatz von SKV-02, ist eine gründliche Reinigung dervorhandenen Tanks und der Maschinenumgebungunerlässlich. Die Tanks und Maschinenumgebungmüssen von allen Rückständen befreit werden, damitein vermischen mit anderen Metallbearbeitungs-mitteln vermieden wird. Zu diesem Zwecke ist esempfehlenswert, das gesamte Kühlsystem mit demReinigungsmittel (Systemcleaner) SC66 (Konzentrat-beigabe 2%) zu reinigen, denn dadurch erreichen Sie ,dass alle schädlichen Stoffe, Rückstände von Alt-emulsionen sowie Leckölen entferntwerden und dieStabilität der Kühlflüssigkeit lange gewahrt bleibt.
Die Wirkung des Reinigungsprozesses wird erhöht,wenn die Reinigungswassertemperatur auf 30° erhöhtwird. Es ist ebenfalls darauf zu achten, dassdasKühlsystem während des Reinigungsvorganges bis zumMaximum gefüllt ist. Das Reinigungsmittel muss restlosaus dem Kühlsystem entfernt sein, bevor mit derNeubefüllung begonnen werden kann.
Weitere Informationen über das Produkt, Risiken, ErsteHilfe, Umwelteinflüsse, Bestandteile und den ordnungs-gemäßen Umgang, erhalten Sie aus dem Sicherheits-datenblatt SKV-02 gemäß 91/255/EWG.
Aufmachung : Kanister 5 und 30 l Inhalt, Fässer 210 l Inhalt und Behälter mit 1000 l Inhalt
Mail :
[email protected] [email protected] , Internet : www.dpi-metalworking.de
