EWAG Novelty: LASER LINE PRECISION
Our world premiere at EMO 2015:
All-in-one laser precision machining of diamond tools The LASER LINE PRECISION uses laser technology as an alternative to grinding and eroding of ultra-hard materials, such as PCD and CVD-D. It can cater for rotationally symmetrical tools of up to 200 mm diameter and up to 250 mm length as well as indexable inserts from 3 mm inscribed diameter and up to 50 mm circumscribed diameter.
The LASER LINE PRECISION is the perfect machine for getting started with laser technology for modern tool manufacturers. The latest fibre laser technology in the green-wavelength range provides efficient machining results in the commercially available diamond cutting materials, such as CBN, PCD and CVD-D. The EWAG Laser Touch Machining® Process can be used to achieve very complex geometries with excellent surface quality.
The LASER LINE PRECISION is the most compact laser production center for diamond tools in the world.
For more details please look
