This solid carbide wood milling cutter is very popular for milling work in plywood in model making and guitar production.
The three-flute cutter with a straight flute gives a clean surface and a flawless milling groove at the bottom.
We stock router bits with cutting edge diameters from 1mm to 3mm.
