Schon mal Danke für die schnellen Antworten...
könnt ihr mir auch sagen wie zur Hölle ich das ganze in dem
Postprozessor einbauen soll? =)
Viele Grüße
FANUC post processor configuration.
$Revision: 41030 1e537f7a89ea5d7051d183af3433708d6c82c0c0 $
$Date: 2016-04-22 22:15:13 $
FORKID {04622D27-72F0-45d4-85FB-DB346FD1AE22}
description = "Generic FANUC";
vendor = "Fanuc";
vendorUrl = "http://www.fanuc.com";
legal = " 2012-2016.";
certificationLevel = 2;
minimumRevision = 24000;
longDescription = "Generic post for Fanuc.";
extension = "nc";
programNameIsInteger = true;
setCodePage("ascii");
capabilities = CAPABILITY_MILLING;
tolerance = spatial(0.002, MM);
minimumChordLength = spatial(0.01, MM);
minimumCircularRadius = spatial(0.01, MM);
maximumCircularRadius = spatial(1000, MM);
minimumCircularSweep = toRad(0.01);
maximumCircularSweep = toRad(180);
allowHelicalMoves = true;
allowedCircularPlanes = undefined; // allow any circular motion
// user-defined properties
properties = {
writeMachine: true, // write machine
writeTools: true, // writes the tools
preloadTool: true, // preloads next tool on tool change if any
showSequenceNumbers: true, // show sequence numbers
sequenceNumberStart: 10, // first sequence number
sequenceNumberIncrement: 5, // increment for sequence numbers
optionalStop: true, // optional stop
o8: false, // specifies 8-digit program number
separateWordsWithSpace: true, // specifies that the words should be separated with a white space
allow3DArcs: false, // specifies that 3D circular arcs are allowed
useRadius: false, // specifies that arcs should be output using the radius (R word) instead of the I, J, and K words
forceIJK: false, // force output of IJK for G2/G3 when not using R word
useParametricFeed: false, // specifies that feed should be output using Q values
showNotes: false, // specifies that operation notes should be output
useSmoothing: false, // specifies if smoothing should be used or not
usePitchForTapping: false, // enable to use pitch instead of feed for the F-word for canned tapping cycles - note that your
CNC control must be setup for pitch mode!
useG95: false // use IPR/MPR instead of IPM/MPM
var permittedCommentChars = " ABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789.,=_-";
var gFormat = createFormat({prefix:"G", width:2, zeropad:true, decimals:1});
var mFormat = createFormat({prefix:"M", width:2, zeropad:true, decimals:1});
var hFormat = createFormat({prefix:"H", width:2, zeropad:true, decimals:1});
var dFormat = createFormat({prefix:"D", width:2, zeropad:true, decimals:1});
var xyzFormat = createFormat({decimals:(unit == MM ? 3 : 4), forceDecimal:true});
var ijkFormat = createFormat({decimals:6, forceDecimal:true}); // unitless
var rFormat = xyzFormat; // radius
var abcFormat = createFormat({decimals:3, forceDecimal:true, scale:DEG});
var feedFormat = createFormat({decimals:(unit == MM ? 0 : 1), forceDecimal:true});
var pitchFormat = createFormat({decimals:(unit == MM ? 3 : 4), forceDecimal:true});
var toolFormat = createFormat({decimals:0});
var rpmFormat = createFormat({decimals:0});
var secFormat = createFormat({decimals:3, forceDecimal:true}); // seconds - range 0.001-99999.999
var milliFormat = createFormat({decimals:0}); // milliseconds // range 1-9999
var taperFormat = createFormat({decimals:1, scale:DEG});
var xOutput = createVariable({prefix:"X"}, xyzFormat);
var yOutput = createVariable({prefix:"Y"}, xyzFormat);
var zOutput = createVariable({prefix:"Z"}, xyzFormat);
var aOutput = createVariable({prefix:"A"}, abcFormat);
var bOutput = createVariable({prefix:"B"}, abcFormat);
var cOutput = createVariable({prefix:"C"}, abcFormat);
var feedOutput = createVariable({prefix:"F"}, feedFormat);
var pitchOutput = createVariable({prefix:"F", force:true}, pitchFormat);
var sOutput = createVariable({prefix:"S", force:true}, rpmFormat);
var dOutput = createVariable({}, dFormat);
// circular output
var iOutput = createReferenceVariable({prefix:"I"}, xyzFormat);
var jOutput = createReferenceVariable({prefix:"J"}, xyzFormat);
var kOutput = createReferenceVariable({prefix:"K"}, xyzFormat);
var gMotionModal = createModal({}, gFormat); // modal group 1 // G0-G3, ...
var gPlaneModal = createModal({onchange:function () {gMotionModal.reset();}}, gFormat); // modal group 2 // G17-19
var gAbsIncModal = createModal({}, gFormat); // modal group 3 // G90-91
var gFeedModeModal = createModal({}, gFormat); // modal group 5 // G94-95
var gUnitModal = createModal({}, gFormat); // modal group 6 // G20-21
var gCycleModal = createModal({}, gFormat); // modal group 9 // G81, ...
var gRetractModal = createModal({}, gFormat); // modal group 10 // G98-99
// fixed settings
var firstFeedParameter = 500;
var useMultiAxisFeatures = true;
var forceMultiAxisIndexing = false; // force multi-axis indexing for 3D programs
var WARNING_WORK_OFFSET = 0;
// collected state
var sequenceNumber;
var currentWorkOffset;
var optionalSection = false;
var forceSpindleSpeed = false;
var activeMovements; // do not use by default
var currentFeedId;
Writes the specified block.
function writeBlock() {
if (properties.showSequenceNumbers) {
if (optionalSection) {
var text = formatWords(arguments);
if (text) {
writeWords("/", "N" + sequenceNumber, text);
} else {
writeWords2("N" + sequenceNumber, arguments);
sequenceNumber += properties.sequenceNumberIncrement;
} else {
writeWords2("/", arguments);
} else {
writeWords(arguments);
Writes the specified optional block.
function writeOptionalBlock() {
var words = formatWords(arguments);
if (words) {
writeWords("/", "N" + sequenceNumber, words);
} else {
function formatComment(text) {
return "(" + filterText(String(text).toUpperCase(), permittedCommentChars).replace(/[\(\)]/g, "") + ")";
Output a comment.
function writeComment(text) {
writeln(formatComment(text));
function onOpen() {
if (false) { // note: setup your machine here
var aAxis = createAxis({coordinate:0, table:false, axis:[1, 0, 0], range:[-360,360], preference:1});
var cAxis = createAxis({coordinate:2, table:false, axis:[0, 0, 1], range:[-360,360], preference:1});
machineConfiguration = new MachineConfiguration(aAxis, cAxis);
setMachineConfiguration(machineConfiguration);
optimizeMachineAngles2(0); // TCP mode
if (!machineConfiguration.isMachineCoordinate(0)) {
aOutput.disable();
if (!machineConfiguration.isMachineCoordinate(1)) {
bOutput.disable();
if (!machineConfiguration.isMachineCoordinate(2)) {
cOutput.disable();
if (!properties.separateWordsWithSpace) {
setWordSeparator("");
if (properties.forceIJK) {
iOutput = createReferenceVariable({prefix:"I", force:true}, xyzFormat);
jOutput = createReferenceVariable({prefix:"J", force:true}, xyzFormat);
kOutput = createReferenceVariable({prefix:"K", force:true}, xyzFormat);
sequenceNumber = properties.sequenceNumberStart;
writeln("%");
if (programName) {
var programId;
try {
programId = getAsInt(programName);
} catch(e) {
error(localize("Program name must be a number."));
return;
if (properties.o8) {
if (!((programId >= 1) && (programId <= 99999999))) {
error(localize("Program number is out of range."));
return;
} else {
if (!((programId >= 1) && (programId <= 9999))) {
return;
if ((programId >= 8000) && (programId <= 9999)) {
warning(localize("Program number is reserved by tool builder."));
var oFormat = createFormat({width:(properties.o8 ? 8 : 4), zeropad:true, decimals:0});
if (programComment) {
writeln("O" + oFormat.format(programId) + " (" + filterText(String(programComment).toUpperCase(), permittedCommentChars) + ")");
} else {
writeln("O" + oFormat.format(programId));
} else {
error(localize("Program name has not been specified."));
return;
// dump machine configuration
var vendor = machineConfiguration.getVendor();
var model = machineConfiguration.getModel();
var description = machineConfiguration.getDescription();
if (properties.writeMachine && (vendor || model || description)) {
writeComment(localize("Machine"));
if (vendor) {
writeComment(" " + localize("vendor") + ": " + vendor);
if (model) {
writeComment(" " + localize("model") + ": " + model);
if (description) {
writeComment(" " + localize("description") + ": " + description);
// dump tool information
if (properties.writeTools) {
var zRanges = {};
if (is3D()) {
var numberOfSections = getNumberOfSections();
for (var i = 0; i < numberOfSections; ++i) {
var section = getSection(i);
var zRange = section.getGlobalZRange();
var tool = section.getTool();
if (zRanges[tool.number]) {
zRanges[tool.number].expandToRange(zRange);
} else {
zRanges[tool.number] = zRange;
var tools = getToolTable();
if (tools.getNumberOfTools() > 0) {
for (var i = 0; i < tools.getNumberOfTools(); ++i) {
var tool = tools.getTool(i);
var comment = "T" + toolFormat.format(tool.number) + " " +
"D=" + xyzFormat.format(tool.diameter) + " " +
localize("CR") + "=" + xyzFormat.format(tool.cornerRadius);
if ((tool.taperAngle > 0) && (tool.taperAngle < Math.PI)) {
comment += " " + localize("TAPER") + "=" + taperFormat.format(tool.taperAngle) + localize("deg");
comment += " - " + localize("ZMIN") + "=" + xyzFormat.format(zRanges[tool.number].getMinimum());
comment += " - " + getToolTypeName(tool.type);
writeComment(comment);
if (false) {
// check for duplicate tool number
for (var i = 0; i < getNumberOfSections(); ++i) {
var sectioni = getSection(i);
var tooli = sectioni.getTool();
for (var j = i + 1; j < getNumberOfSections(); ++j) {
var sectionj = getSection(j);
var toolj = sectionj.getTool();
if (tooli.number == toolj.number) {
if (xyzFormat.areDifferent(tooli.diameter, toolj.diameter) ||
xyzFormat.areDifferent(tooli.cornerRadius, toolj.cornerRadius) ||
abcFormat.areDifferent(tooli.taperAngle, toolj.taperAngle) ||
(tooli.numberOfFlutes != toolj.numberOfFlutes)) {
error(
subst(
localize("Using the same tool number for different cutter geometry for operation '%1' and '%2'."),
sectioni.hasParameter("operation-comment") ? sectioni.getParameter("operation-comment") : ("#" + (i + 1)),
sectionj.hasParameter("operation-comment") ? sectionj.getParameter("operation-comment") : ("#" + (j + 1))
return;
// absolute coordinates and feed per min
writeBlock(gAbsIncModal.format(90), gFeedModeModal.format(properties.useG95 ? 95 : 94), gPlaneModal.format(17), gFormat.format(49), gFormat.format(40), gFormat.format(80));
switch (unit) {
case IN:
writeBlock(gUnitModal.format(20));
break;
case MM:
writeBlock(gUnitModal.format(21));
break;
if (properties.useG95 && properties.useParametricFeed) {
error(localize("Parametric feed is not supported when using G95."));
return;
if (properties.useG95) {
feedFormat = createFormat({decimals:(unit == MM ? 4 : 5), forceDecimal:true});
function onComment(message) {
var comments = String(message).split(";");
for (comment in comments) {
writeComment(comments[comment]);
/** Force output of X, Y, and Z. */
function forceXYZ() {
xOutput.reset();
yOutput.reset();
zOutput.reset();
/** Force output of A, B, and C. */
function forceABC() {
aOutput.reset();
bOutput.reset();
cOutput.reset();
function forceFeed() {
currentFeedId = undefined;
feedOutput.reset();
/** Force output of X, Y, Z, A, B, C, and F on next output. */
function forceAny() {
forceXYZ();
forceABC();
forceFeed();
var lengthCompensationActive = false;
var retracted = false; // specifies that the tool has been retracted to the safe plane
/** Disables length compensation if currently active or if forced. */
function disableLengthCompensation(force) {
if (lengthCompensationActive || force) {
validate(retracted, "Cannot cancel length compensation if the machine is not fully retracted.");
writeBlock(gFormat.format(49));
var currentSmoothing = false;
function setSmoothing(mode) {
if (mode == currentSmoothing) {
return false;
// 1) Make sure G49 is called before the execution of G05.1 Q1 Rx
// 2) G05.1 Q1 Rx must be engaged BEFORE G43-Tool Length Comp
// 3) AICC and AIAPC need to be turned on and off for each tool
// 4) AICC and AIAPC does not apply to canned drilling cycles
validate(!lengthCompensationActive, "Length compensation is active while trying to update smoothing.");
currentSmoothing = mode;
writeBlock(gFormat.format(5.1), mode ? "Q1" : "Q0");
return true;
function FeedContext(id, description, feed) {
this.id = id;
this.description = description;
this.feed = feed;
function getFeed(f) {
return feedOutput.format(f/spindleSpeed); // use feed value
if (activeMovements) {
var feedContext = activeMovements[movement];
if (feedContext != undefined) {
if (!feedFormat.areDifferent(feedContext.feed, f)) {
if (feedContext.id == currentFeedId) {
return ""; // nothing has changed
forceFeed();
currentFeedId = feedContext.id;
return "F#" + (firstFeedParameter + feedContext.id);
currentFeedId = undefined; // force Q feed next time
return feedOutput.format(f); // use feed value
function initializeActiveFeeds() {
activeMovements = new Array();
var movements = currentSection.getMovements();
var id = 0;
var activeFeeds = new Array();
if (hasParameter("operation:tool_feedCutting")) {
if (movements & ((1 << MOVEMENT_CUTTING) | (1 << MOVEMENT_LINK_TRANSITION) | (1 << MOVEMENT_EXTENDED))) {
var feedContext = new FeedContext(id, localize("Cutting"), getParameter("operation:tool_feedCutting"));
activeFeeds.push(feedContext);
activeMovements[MOVEMENT_CUTTING] = feedContext;
activeMovements[MOVEMENT_LINK_TRANSITION] = feedContext;
activeMovements[MOVEMENT_EXTENDED] = feedContext;
++id;
if (movements & (1 << MOVEMENT_PREDRILL)) {
feedContext = new FeedContext(id, localize("Predrilling"), getParameter("operation:tool_feedCutting"));
activeMovements[MOVEMENT_PREDRILL] = feedContext;
++id;
if (hasParameter("operation:finishFeedrate")) {
if (movements & (1 << MOVEMENT_FINISH_CUTTING)) {
var feedContext = new FeedContext(id, localize("Finish"), getParameter("operation:finishFeedrate"));
activeMovements[MOVEMENT_FINISH_CUTTING] = feedContext;
++id;
} else if (hasParameter("operation:tool_feedCutting")) {
var feedContext = new FeedContext(id, localize("Finish"), getParameter("operation:tool_feedCutting"));
++id;
if (hasParameter("operation:tool_feedEntry")) {
if (movements & (1 << MOVEMENT_LEAD_IN)) {
var feedContext = new FeedContext(id, localize("Entry"), getParameter("operation:tool_feedEntry"));
activeMovements[MOVEMENT_LEAD_IN] = feedContext;
++id;
if (hasParameter("operation:tool_feedExit")) {
if (movements & (1 << MOVEMENT_LEAD_OUT)) {
var feedContext = new FeedContext(id, localize("Exit"), getParameter("operation:tool_feedExit"));
activeMovements[MOVEMENT_LEAD_OUT] = feedContext;
++id;
if (hasParameter("operation:noEngagementFeedrate")) {
if (movements & (1 << MOVEMENT_LINK_DIRECT)) {
var feedContext = new FeedContext(id, localize("Direct"), getParameter("operation:noEngagementFeedrate"));
activeMovements[MOVEMENT_LINK_DIRECT] = feedContext;
++id;
} else if (hasParameter("operation:tool_feedCutting") &&
hasParameter("operation:tool_feedEntry") &&
var feedContext = new FeedContext(id, localize("Direct"), Math.max(getParameter("operation:tool_feedCutting"), getParameter("operation:tool_feedEntry"), getParameter("operation:tool_feedExit")));
++id;
if (hasParameter("operation:reducedFeedrate")) {
if (movements & (1 << MOVEMENT_REDUCED)) {
var feedContext = new FeedContext(id, localize("Reduced"), getParameter("operation:reducedFeedrate"));
activeMovements[MOVEMENT_REDUCED] = feedContext;
++id;
if (hasParameter("operation:tool_feedRamp")) {
if (movements & ((1 << MOVEMENT_RAMP) | (1 << MOVEMENT_RAMP_HELIX) | (1 << MOVEMENT_RAMP_PROFILE) | (1 << MOVEMENT_RAMP_ZIG_ZAG))) {
var feedContext = new FeedContext(id, localize("Ramping"), getParameter("operation:tool_feedRamp"));
activeMovements[MOVEMENT_RAMP] = feedContext;
activeMovements[MOVEMENT_RAMP_HELIX] = feedContext;
activeMovements[MOVEMENT_RAMP_PROFILE] = feedContext;
activeMovements[MOVEMENT_RAMP_ZIG_ZAG] = feedContext;
++id;
if (hasParameter("operation:tool_feedPlunge")) {
if (movements & (1 << MOVEMENT_PLUNGE)) {
var feedContext = new FeedContext(id, localize("Plunge"), getParameter("operation:tool_feedPlunge"));
activeMovements[MOVEMENT_PLUNGE] = feedContext;
++id;
if (true) { // high feed
if (movements & (1 << MOVEMENT_HIGH_FEED)) {
var feedContext = new FeedContext(id, localize("High Feed"), this.highFeedrate);
activeMovements[MOVEMENT_HIGH_FEED] = feedContext;
++id;
for (var i = 0; i < activeFeeds.length; ++i) {
var feedContext = activeFeeds[i];
writeBlock("#" + (firstFeedParameter + feedContext.id) + "=" + feedFormat.format(feedContext.feed), formatComment(feedContext.description));
var currentWorkPlaneABC = undefined;
function forceWorkPlane() {
function setWorkPlane(abc) {
if (!forceMultiAxisIndexing && is3D() && !machineConfiguration.isMultiAxisConfiguration()) {
return; // ignore
if (!((currentWorkPlaneABC == undefined) ||
abcFormat.areDifferent(abc.x, currentWorkPlaneABC.x) ||
abcFormat.areDifferent(abc.y, currentWorkPlaneABC.y) ||
abcFormat.areDifferent(abc.z, currentWorkPlaneABC.z))) {
return; // no change
onCommand(COMMAND_UNLOCK_MULTI_AXIS);
if (useMultiAxisFeatures) {
if (abc.isNonZero()) {
writeBlock(gFormat.format(68.2), "X" + xyzFormat.format(0), "Y" + xyzFormat.format(0), "Z" + xyzFormat.format(0), "I" + abcFormat.format(abc.x), "J" + abcFormat.format(abc.y), "K" + abcFormat.format(abc.z)); // set frame
writeBlock(gFormat.format(53.1)); // turn machine
} else {
writeBlock(gFormat.format(69)); // cancel frame
} else {
writeBlock(
gMotionModal.format(0),
conditional(machineConfiguration.isMachineCoordinate(0), "A" + abcFormat.format(abc.x)),
conditional(machineConfiguration.isMachineCoordinate(1), "B" + abcFormat.format(abc.y)),
conditional(machineConfiguration.isMachineCoordinate(2), "C" + abcFormat.format(abc.z))
onCommand(COMMAND_LOCK_MULTI_AXIS);
currentWorkPlaneABC = abc;
var closestABC = false; // choose closest machine angles
var currentMachineABC;
function getWorkPlaneMachineABC(workPlane) {
var W = workPlane; // map to global frame
var abc = machineConfiguration.getABC(W);
if (closestABC) {
if (currentMachineABC) {
abc = machineConfiguration.remapToABC(abc, currentMachineABC);
} else {
abc = machineConfiguration.getPreferredABC(abc);
} else {
try {
abc = machineConfiguration.remapABC(abc);
currentMachineABC = abc;
} catch (e) {
error(
localize("Machine angles not supported") + ":"
+ conditional(machineConfiguration.isMachineCoordinate(0), " A" + abcFormat.format(abc.x))
+ conditional(machineConfiguration.isMachineCoordinate(1), " B" + abcFormat.format(abc.y))
+ conditional(machineConfiguration.isMachineCoordinate(2), " C" + abcFormat.format(abc.z))
var direction = machineConfiguration.getDirection(abc);
if (!isSameDirection(direction, W.forward)) {
error(localize("Orientation not supported."));
if (!machineConfiguration.isABCSupported(abc)) {
error(
localize("Work plane is not supported") + ":"
var tcp = false;
if (tcp) {
setRotation(W); // TCP mode
} else {
var O = machineConfiguration.getOrientation(abc);
var R = machineConfiguration.getRemainingOrientation(abc, W);
setRotation®;
return abc;
function onSection() {
var forceToolAndRetract = optionalSection && !currentSection.isOptional();
optionalSection = currentSection.isOptional();
var insertToolCall = forceToolAndRetract || isFirstSection() ||
currentSection.getForceToolChange && currentSection.getForceToolChange() ||
(tool.number != getPreviousSection().getTool().number);
var newWorkOffset = isFirstSection() ||
(getPreviousSection().workOffset != currentSection.workOffset); // work offset changes
var newWorkPlane = isFirstSection() ||
!isSameDirection(getPreviousSection().getGlobalFinalToolAxis(), currentSection.getGlobalInitialToolAxis());
if (insertToolCall || newWorkOffset || newWorkPlane) {
// stop spindle before retract during tool change
if (insertToolCall && !isFirstSection()) {
onCommand(COMMAND_STOP_SPINDLE);
// retract to safe plane
retracted = true;
writeBlock(gFormat.format(28), gAbsIncModal.format(91), "Z" + xyzFormat.format(0)); // retract
writeBlock(gAbsIncModal.format(90));
forceXYZ();
disableLengthCompensation();
setSmoothing(false);
writeln("");
if (hasParameter("operation-comment")) {
var comment = getParameter("operation-comment");
if (comment) {
if (properties.showNotes && hasParameter("notes")) {
var notes = getParameter("notes");
if (notes) {
var lines = String(notes).split("\n");
var r1 = new RegExp("^[\\s]+", "g");
var r2 = new RegExp("[\\s]+$", "g");
for (line in lines) {
var comment = lines[line].replace(r1, "").replace(r2, "");
if (comment) {
if (insertToolCall) {
forceWorkPlane();
retracted = true;
onCommand(COMMAND_COOLANT_OFF);
if (!isFirstSection() && properties.optionalStop) {
onCommand(COMMAND_OPTIONAL_STOP);
if (tool.number > 99) {
warning(localize("Tool number exceeds maximum value."));
writeBlock("T" + toolFormat.format(tool.number), mFormat.format(6));
if (tool.comment) {
writeComment(tool.comment);
var showToolZMin = false;
if (showToolZMin) {
if (is3D()) {
var zRange = currentSection.getGlobalZRange();
var number = tool.number;
for (var i = currentSection.getId() + 1; i < numberOfSections; ++i) {
if (section.getTool().number != number) {
break;
zRange.expandToRange(section.getGlobalZRange());
writeComment(localize("ZMIN") + "=" + zRange.getMinimum());
if (properties.preloadTool) {
var nextTool = getNextTool(tool.number);
if (nextTool) {
writeBlock("T" + toolFormat.format(nextTool.number));
} else {
// preload first tool
var section = getSection(0);
var firstToolNumber = section.getTool().number;
if (tool.number != firstToolNumber) {
writeBlock("T" + toolFormat.format(firstToolNumber));
forceSpindleSpeed ||
isFirstSection() ||
(rpmFormat.areDifferent(tool.spindleRPM, sOutput.getCurrent())) ||
(tool.clockwise != getPreviousSection().getTool().clockwise)) {
if (tool.spindleRPM < 1) {
error(localize("Spindle speed out of range."));
return;
if (tool.spindleRPM > 99999) {
warning(localize("Spindle speed exceeds maximum value."));
writeBlock(
sOutput.format(tool.spindleRPM), mFormat.format(tool.clockwise ? 3 : 4)
onCommand(COMMAND_START_CHIP_TRANSPORT);
if (forceMultiAxisIndexing || !is3D() || machineConfiguration.isMultiAxisConfiguration()) {
// writeBlock(mFormat.format(xxx)); // shortest path traverse
// wcs
if (insertToolCall) { // force work offset when changing tool
currentWorkOffset = undefined;
var workOffset = currentSection.workOffset;
if (workOffset == 0) {
warningOnce(localize("Work offset has not been specified. Using G54 as WCS."), WARNING_WORK_OFFSET);
workOffset = 1;
if (workOffset > 0) {
if (workOffset > 6) {
var p = workOffset - 6; // 1->...
if (p > 300) {
error(localize("Work offset out of range."));
return;
} else {
if (workOffset != currentWorkOffset) {
writeBlock(gFormat.format(54.1), "P" + p); // G54.1P
currentWorkOffset = workOffset;
} else {
writeBlock(gFormat.format(53 + workOffset)); // G54->G59
forceXYZ();
if (forceMultiAxisIndexing || !is3D() || machineConfiguration.isMultiAxisConfiguration()) { // use 5-axis indexing for multi-axis mode
// set working plane after datum shift
if (currentSection.isMultiAxis()) {
forceWorkPlane();
cancelTransformation();
} else {
var abc = new Vector(0, 0, 0);
var eulerXYZ = currentSection.workPlane.getTransposed().eulerZYX_R;
abc = new Vector(-eulerXYZ.x, -eulerXYZ.y, -eulerXYZ.z);
} else {
abc = getWorkPlaneMachineABC(currentSection.workPlane);
setWorkPlane(abc);
} else { // pure 3D
var remaining = currentSection.workPlane;
if (!isSameDirection(remaining.forward, new Vector(0, 0, 1))) {
error(localize("Tool orientation is not supported."));
return;
setRotation(remaining);
// set coolant after we have positioned at Z
setCoolant(tool.coolant);
if (properties.useSmoothing) {
if (hasParameter("operation-strategy") && (getParameter("operation-strategy") != "drill")) {
if (setSmoothing(true)) {
// we force G43 using lengthCompensationActive
} else {
if (setSmoothing(false)) {
forceAny();
var initialPosition = getFramePosition(currentSection.getInitialPosition());
if (!retracted) {
if (getCurrentPosition().z < initialPosition.z) {
writeBlock(gMotionModal.format(0), zOutput.format(initialPosition.z));
if (insertToolCall || !lengthCompensationActive || retracted || (!isFirstSection() && getPreviousSection().isMultiAxis())) {
var lengthOffset = tool.lengthOffset;
if (lengthOffset > 99) {
error(localize("Length offset out of range."));
return;
writeBlock(gPlaneModal.format(17));
if (!machineConfiguration.isHeadConfiguration()) {
writeBlock(
gMotionModal.format(0), xOutput.format(initialPosition.x), yOutput.format(initialPosition.y)
writeBlock(gMotionModal.format(0), gFormat.format(currentSection.isMultiAxis() ? 43.5 : 43), zOutput.format(initialPosition.z), hFormat.format(lengthOffset));
lengthCompensationActive = true;
} else {
writeBlock(
gFormat.format(currentSection.isMultiAxis() ? (machineConfiguration.isMultiAxisConfiguration() ? 43.4 : 43.5) : 43),
yOutput.format(initialPosition.y),
} else {
writeBlock(
validate(lengthCompensationActive, "Length compensation is not active.");
if (properties.useParametricFeed &&
if (!insertToolCall &&
activeMovements &&
(getCurrentSectionId() > 0) &&
(getPreviousSection().getPatternId() == currentSection.getPatternId())) {
// use the current feeds
} else {
initializeActiveFeeds();
} else {
activeMovements = undefined;
retracted = false;
function onDwell(seconds) {
if (seconds > 99999.999) {
warning(localize("Dwelling time is out of range."));
milliseconds = clamp(1, seconds * 1000, 99999999);
writeBlock(gFeedModeModal.format(94), gFormat.format(4), "P" + milliFormat.format(milliseconds));
writeBlock(gFeedModeModal.format(properties.useG95 ? 95 : 94)); // back to G95
function onSpindleSpeed(spindleSpeed) {
writeBlock(sOutput.format(spindleSpeed));
function onCycle() {
function getCommonCycle(x, y, z, r) {
forceXYZ(); // force xyz on first drill hole of any cycle
return [xOutput.format(x), yOutput.format(y),
zOutput.format(z),
"R" + xyzFormat.format®];
function onCyclePoint(x, y, z) {
if (isFirstCyclePoint()) {
repositionToCycleClearance(cycle, x, y, z);
// return to initial Z which is clearance plane and set absolute mode
var F = cycle.feedrate;
F = F/spindleSpeed;
var P = (cycle.dwell == 0) ? 0 : clamp(1, cycle.dwell * 1000, 99999999); // in milliseconds
switch (cycleType) {
case "drilling":
writeBlock(
gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(81),
getCommonCycle(x, y, z, cycle.retract),
feedOutput.format(F)
break;
case "counter-boring":
if (P > 0) {
writeBlock(
gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(82),
"P" + milliFormat.format(P),
} else {
writeBlock(
break;
case "chip-breaking":
// cycle.accumulatedDepth is ignored
if (P > 0) {
expandCyclePoint(x, y, z);
} else {
writeBlock(
gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(73),
"Q" + xyzFormat.format(cycle.incrementalDepth),
break;
case "deep-drilling":
if (P > 0) {
} else {
writeBlock(
gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(83),
// conditional(P > 0, "P" + milliFormat.format(P)),
break;
case "tapping":
writeBlock(mFormat.format(29), sOutput.format(tool.spindleRPM));
if (properties.usePitchForTapping) {
writeBlock(
gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format((tool.type == TOOL_TAP_LEFT_HAND) ? 74 : 84),
pitchOutput.format(tool.threadPitch)
forceFeed();
} else {
writeBlock(
break;
case "left-tapping":
writeBlock(
gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(74),
forceFeed();
} else {
writeBlock(
feedOutput.format(properties.useG95 ? tool.getTappingFeedrate()/spindleSpeed : tool.getTappingFeedrate())
break;
case "right-tapping":
writeBlock(
gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(84),
forceFeed();
} else {
writeBlock(
break;
case "tapping-with-chip-breaking":
case "left-tapping-with-chip-breaking":
case "right-tapping-with-chip-breaking":
writeBlock(
gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format((tool.type == TOOL_TAP_LEFT_HAND ? 74 : 84)),
forceFeed();
} else {
writeBlock(
break;
case "fine-boring":
writeBlock(
gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(76),
"P" + milliFormat.format(P), // not optional
"Q" + xyzFormat.format(cycle.shift),
break;
case "back-boring":
var dx = (gPlaneModal.getCurrent() == 19) ? cycle.backBoreDistance : 0;
var dy = (gPlaneModal.getCurrent() == 18) ? cycle.backBoreDistance : 0;
var dz = (gPlaneModal.getCurrent() == 17) ? cycle.backBoreDistance : 0;
writeBlock(
gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(87),
getCommonCycle(x - dx, y - dy, z - dz, cycle.bottom),
break;
case "reaming":
if (P > 0) {
writeBlock(
gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(89),
} else {
writeBlock(
gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(85),
break;
case "stop-boring":
if (P > 0) {
} else {
writeBlock(
gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(86),
break;
case "manual-boring":
writeBlock(
gRetractModal.format(98), gAbsIncModal.format(90), gCycleModal.format(88),
break;
case "boring":
if (P > 0) {
writeBlock(
} else {
writeBlock(
break;
default:
} else {
if (cycleExpanded) {
} else {
writeBlock(xOutput.format(x), yOutput.format(y));
function onCycleEnd() {
if (!cycleExpanded) {
writeBlock(gCycleModal.format(80));
zOutput.reset();
var pendingRadiusCompensation = -1;
function onRadiusCompensation() {
pendingRadiusCompensation = radiusCompensation;
function onRapid(_x, _y, _z) {
var x = xOutput.format(_x);
var y = yOutput.format(_y);
var z = zOutput.format(_z);
if (x || y || z) {
if (pendingRadiusCompensation >= 0) {
error(localize("Radius compensation mode cannot be changed at rapid traversal."));
return;
writeBlock(gMotionModal.format(0), x, y, z);
forceFeed();
function onLinear(_x, _y, _z, feed) {
var f = getFeed(feed);
if (x || y || z) {
var d = tool.diameterOffset;
if (d > 99) {
warning(localize("The diameter offset exceeds the maximum value."));
switch (radiusCompensation) {
case RADIUS_COMPENSATION_LEFT:
dOutput.reset();
writeBlock(gMotionModal.format(1), gFormat.format(41), x, y, z, dOutput.format(d), f);
break;
case RADIUS_COMPENSATION_RIGHT:
dOutput.reset();
writeBlock(gMotionModal.format(1), gFormat.format(42), x, y, z, dOutput.format(d), f);
break;
default:
writeBlock(gMotionModal.format(1), gFormat.format(40), x, y, z, f);
} else {
writeBlock(gMotionModal.format(1), x, y, z, f);
} else if (f) {
if (getNextRecord().isMotion()) { // try not to output feed without motion
forceFeed(); // force feed on next line
} else {
writeBlock(gMotionModal.format(1), f);
function onRapid5D(_x, _y, _z, _a, _b, _c) {
return;
if (currentSection.isOptimizedForMachine()) {
var a = aOutput.format(_a);
var b = bOutput.format(_b);
var c = cOutput.format(_c);
writeBlock(gMotionModal.format(0), x, y, z, a, b, c);
} else {
forceXYZ();
var i = ijkFormat.format(_a);
var j = ijkFormat.format(_b);
var k = ijkFormat.format(_c);
writeBlock(gMotionModal.format(0), x, y, z, "I" + i, "J" + j, "K" + k);
forceFeed();
function onLinear5D(_x, _y, _z, _a, _b, _c, feed) {
error(localize("Radius compensation cannot be activated/deactivated for 5-axis move."));
return;
if (x || y || z || a || b || c) {
writeBlock(gMotionModal.format(1), x, y, z, a, b, c, f);
} else if (f) {
} else {
} else {
forceXYZ();
if (x || y || z || i || j || k) {
writeBlock(gMotionModal.format(1), x, y, z, "I" + i, "J" + j, "K" + k, f);
} else if (f) {
} else {
function onCircular(clockwise, cx, cy, cz, x, y, z, feed) {
error(localize("Radius compensation cannot be activated/deactivated for a circular move."));
return;
var start = getCurrentPosition();
if (isFullCircle()) {
if (properties.useRadius || isHelical()) { // radius mode does not support full arcs
linearize(tolerance);
return;
switch (getCircularPlane()) {
case PLANE_XY:
writeBlock(gAbsIncModal.format(90), gPlaneModal.format(17), gMotionModal.format(clockwise ? 2 : 3), iOutput.format(cx - start.x, 0), jOutput.format(cy - start.y, 0), getFeed(feed));
break;
case PLANE_ZX:
writeBlock(gAbsIncModal.format(90), gPlaneModal.format(18), gMotionModal.format(clockwise ? 2 : 3), iOutput.format(cx - start.x, 0), kOutput.format(cz - start.z, 0), getFeed(feed));
break;
case PLANE_YZ:
writeBlock(gAbsIncModal.format(90), gPlaneModal.format(19), gMotionModal.format(clockwise ? 2 : 3), jOutput.format(cy - start.y, 0), kOutput.format(cz - start.z, 0), getFeed(feed));
break;
default:
} else if (!properties.useRadius) {
case PLANE_XY:
writeBlock(gAbsIncModal.format(90), gPlaneModal.format(17), gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), yOutput.format(y), zOutput.format(z), iOutput.format(cx - start.x, 0), jOutput.format(cy - start.y, 0), getFeed(feed));
break;
case PLANE_ZX:
writeBlock(gAbsIncModal.format(90), gPlaneModal.format(18), gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), yOutput.format(y), zOutput.format(z), iOutput.format(cx - start.x, 0), kOutput.format(cz - start.z, 0), getFeed(feed));
break;
case PLANE_YZ:
writeBlock(gAbsIncModal.format(90), gPlaneModal.format(19), gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), yOutput.format(y), zOutput.format(z), jOutput.format(cy - start.y, 0), kOutput.format(cz - start.z, 0), getFeed(feed));
break;
default:
if (properties.allow3DArcs) {
// make sure maximumCircularSweep is well below 360deg
// we could use G02.4 or G03.4 - direction is calculated
var ip = getPositionU(0.5);
writeBlock(gAbsIncModal.format(90), gMotionModal.format(clockwise ? 2.4 : 3.4), xOutput.format(ip.x), yOutput.format(ip.y), zOutput.format(ip.z));
writeBlock(xOutput.format(x), yOutput.format(y), zOutput.format(z), getFeed(feed));
} else {
} else { // use radius mode
var r = getCircularRadius();
if (toDeg(getCircularSweep()) > (180 + 1e-9)) {
r = -r; // allow up to <360 deg arcs
case PLANE_XY:
writeBlock(gPlaneModal.format(17), gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), yOutput.format(y), zOutput.format(z), "R" + rFormat.format®, getFeed(feed));
break;
case PLANE_ZX:
writeBlock(gPlaneModal.format(18), gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), yOutput.format(y), zOutput.format(z), "R" + rFormat.format®, getFeed(feed));
break;
case PLANE_YZ:
writeBlock(gPlaneModal.format(19), gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), yOutput.format(y), zOutput.format(z), "R" + rFormat.format®, getFeed(feed));
break;
default:
} else {
var currentCoolantMode = COOLANT_OFF;
function setCoolant(coolant) {
if (coolant == currentCoolantMode) {
return; // coolant is already active
if (coolant == COOLANT_OFF) {
writeBlock(mFormat.format((currentCoolantMode == COOLANT_THROUGH_TOOL) ? 89 : 9));
return;
var m;
switch (coolant) {
case COOLANT_FLOOD:
m = 8;
break;
case COOLANT_THROUGH_TOOL:
m = 88;
break;
default:
onUnsupportedCoolant(coolant);
m = 9;
if (m) {
writeBlock(mFormat.format(m));
currentCoolantMode = coolant;
var mapCommand = {
COMMAND_STOP:0,
COMMAND_OPTIONAL_STOP:1,
COMMAND_END:2,
COMMAND_SPINDLE_CLOCKWISE:3,
COMMAND_SPINDLE_COUNTERCLOCKWISE:4,
COMMAND_STOP_SPINDLE:5,
COMMAND_ORIENTATE_SPINDLE:19
function onCommand(command) {
switch (command) {
case COMMAND_COOLANT_OFF:
setCoolant(COOLANT_OFF);
return;
case COMMAND_COOLANT_ON:
setCoolant(COOLANT_FLOOD);
return;
case COMMAND_STOP:
writeBlock(mFormat.format(0));
forceSpindleSpeed = true;
return;
case COMMAND_START_SPINDLE:
onCommand(tool.clockwise ? COMMAND_SPINDLE_CLOCKWISE : COMMAND_SPINDLE_COUNTERCLOCKWISE);
return;
case COMMAND_LOCK_MULTI_AXIS:
return;
case COMMAND_UNLOCK_MULTI_AXIS:
return;
case COMMAND_START_CHIP_TRANSPORT:
return;
case COMMAND_STOP_CHIP_TRANSPORT:
return;
case COMMAND_BREAK_CONTROL:
return;
case COMMAND_TOOL_MEASURE:
return;
var stringId = getCommandStringId(command);
var mcode = mapCommand[stringId];
if (mcode != undefined) {
writeBlock(mFormat.format(mcode));
} else {
onUnsupportedCommand(command);
function onSectionEnd() {
if (((getCurrentSectionId() + 1) >= getNumberOfSections()) ||
(tool.number != getNextSection().getTool().number)) {
onCommand(COMMAND_BREAK_CONTROL);
forceAny();
function onClose() {
writeln("");
retracted = true;
disableLengthCompensation(true);
zOutput.reset();
setWorkPlane(new Vector(0, 0, 0)); // reset working plane
if (!machineConfiguration.hasHomePositionX() && !machineConfiguration.hasHomePositionY()) {
// 90/91 mode is don't care
writeBlock(gFormat.format(28), gAbsIncModal.format(91), "X" + xyzFormat.format(0), "Y" + xyzFormat.format(0)); // return to home
} else {
var homeX;
if (machineConfiguration.hasHomePositionX()) {
homeX = "X" + xyzFormat.format(machineConfiguration.getHomePositionX());
var homeY;
if (machineConfiguration.hasHomePositionY()) {
homeY = "Y" + xyzFormat.format(machineConfiguration.getHomePositionY());
writeBlock(gAbsIncModal.format(90), gFormat.format(53), gMotionModal.format(0), homeX, homeY);
onImpliedCommand(COMMAND_END);
onImpliedCommand(COMMAND_STOP_SPINDLE);
writeBlock(mFormat.format(30)); // stop program, spindle stop, coolant off
writeln("%");
