QUOTE (Frankenstein @ 11.01.06 - 11:50)
The principal use of the Cut Link Distance parameter is to reduce the number of retracts by allowing the cutting feed rate to be continued over a distance where, without this parameter, WorkNC would normally perform a retract.
That means: each distance closer than the programed value will be done in cut feedrate instead of making a possible retract.
Thanks again
