Te-Shin Cam Co
12
Te-Shin Cam Co
12
ZERO-BACKLASH Roller Cam Table
te-shin-cam news Image
Roller cam drive
Features advantages:
1. Zero backlash:
Rolling contact between the roller and the cam, no
positive reversal backlash problem, greatly improving the
ultra-precision characteristics of the roller cam, reducing
the defect rate and improving the quality, which is a
breakthrough for precision machining technology.
2. Ultra-high efficiency conduction:
Roller cam type turret conducts in rolling mode,
reduces wear, high transmission efficiency, high
speed operation, and conduction efficiency of over
90%.
3. No thermal displacement:
Even at high speeds, reduce friction, reduce thermal
displacement, improve quality stability, and reduce
non-performing rates.
4. Maintenance-free:
Due to low wear and low aging, it can maintain initial
accuracy for a long time.
5. Long life:
Roller conduction method, can reduce wear and have
long service life.
6. Braking performance:
When the brake is positioned, the disc surface will not
sway back and forth, and the positioning brake will
remain within 2um, which can highly demonstrate the
precision machining quality.
Verantwortlich für den Inhalt dieser Pressemitteilung: Te-Shin Cam Co., Ltd.
