MOOG GAT
13
MOOG GAT
13
Rotary Unions and Slip Rings for Robotics Applications
moog-gat news Image
Ultra-light combination for Cobots
Collaborating robots (short "Cobots") support people in the immediate vicinity in assembly work, the so-called human / robot collaboration (short "HRC"). We developed a combination of slip ring and rotary union for robot-guided, automated screwdriving processes with plastic screws and monitoring of the torque.
The screw is guided and positioned with a vacuum. A control loop terminates the tightening process when the max. torque is reached. With its steel shaft, this combination can absorb the resulting forces and torques, but at the same time it is also weight-optimised, so that it can be used on robots with a lower load capacity.
Reliable transmission of PROFINET
With a combination of an electrical slip ring for communication (Industrial Ethernet) and 8 pneumatic channels, suitably designed as an element between robot arm and tool, rotations of more than 360° and several clamping processes can be realized in conjunction with continuous monitoring and communication for a wide range of applications.
This device can accommodate torques corresponding to the size. The 8 pneumatic channels enable flexible use in changing tasks or later upgrading of your production system.
Verantwortlich für den Inhalt dieser Pressemitteilung: Moog GAT GmbH
Moog GAT GmbH
